converting voltage into pressure
ihebz1
Member
Message contains an image
Hey guys I'm working on this LabVIEW Arduino interface  project I'm trying to measure  the pressure of a pump(max pressure of the pump is 70kpa) using an mpx5700dp sensor  .. my problem is I need to convert the voltage into pressure and display it on the
waveform using this transfer function .... can someone help me undertand it pls
10 REPLIES 10
altenbach
Knight of NI
Re: converting voltage into pressure
Well, it's a simple linear formula (until it falls apart at high pressures), so all you need is implement the math given in the picture using three diagram constants (slope, offset, excitation voltage). What have you tried?
ihebz1
Member
the problem is  I didn't understand it I made the interface  but I didn't know how to get the slope the excitation voltage and the offset  the maximum pressure of the pump is 70kpa convert lab.PNG
altenbach
Knight of NI
Just change the constants to the values from the picture. Zeroes are not useful.
Of course you need to solve the formula for P(Vout), given the constants.
ihebz1
Member
the offset voltage is 0 because it is linear but the sensitivity I didn't get is what I'm supposed to put
altenbach
Knight of NI
That sentence makes no sense in so many ways! Did you look at my picture?
Also note that you don't need the separate pressure indicator if you show the digital display of the chart. We can typically offer much more specific help if you would attach your VI
crossrulz
Knight of NI
Read the transfer function straight from the data you already gave (ignore the "error" part):
Vout = Vs*(0.0012858*P+0.04)
So solve for P (basic algebra):
P = ((Vout/Vs) - 0.04) / 0.0012858 = ((Vout/Vs)-0.04)*777.726 = 777.726*Vout/Vs - 31.109
So your gain is: 777.726/Vs
and your offset is: -31.109
ihebz1
Member
from where  the 777.726 came from ,, also -31.109
ihebz1
Member
Message contains an attachment
proland1121
Member
it's literally just algebra, he even wrote it all out for you.  did you get enough sleep last night?
Tags (1)
