converting text inbox
Hello
I am a first time labview user and I'm trying to make a GUI. How do I convert an Indicator to a control using  a press button. What I am trying to do is to activate a text box whixh is an indicator to a control once the press button is pushed and also another control box would simultaneously change to an indicator. I hope this question makes sense.
thank you
(2,957 Views)
First, you can't post links to images that reside on your hard driver (unless you are running a web server) so none of the images are present. Second, you can't programtically change an indicator to a control or a control to an indicator. You can make it appear that is what is happening though. Look here for some suggestions.
(2,946 Views)
