converting string to column array
Hi, I have a string of data e.g. Test. I want to put every each single char of such random string seperately to column array (vector) - every element of string is one element of array. Can you simply explain how to do it? regards, Marcin
(5,436 Views)
I'm thinking string to Byte array and then typecast the bytes back into strings.
There might be a more efficient way though.
(5,427 Views)
that's the traditional way (ever learned BASIC and used mid$?):
(5,409 Views)
You can use Match Pattern too, just for fun.
Jim
(5,396 Views)
Adding to the fun:
There has to be a few more ways.
Edit:  In case we have yet to cross over into the ridiculous:
(5,392 Views)
Thank you guys, I have to implement all of these solutions and test it. Thanks a lot 🙂
(5,368 Views)
Don't test. All you need is the first one... and you can even leave out the string constant wired to the typecast function. 😄
(5,361 Views)
