converting enum into varient
I undestant output of enum is index value I expect that index i am changing to varient and back to integer value. Is there any thing wrong in my concept.
Message 11 of 14
(776 Views)
I think the problem here is that we don't know what you are trying to ultimately accomplish, as you haven't really explained this. For the example you posted, as crossrulz mentioned, all you need is an I32 conversion bullet - there is no reason for a variant. You mention you have 200 additional cases. 200 additional cases of what? We are just guessing around the problem here, and it's difficult for us to help you unless you provide a better explanation of the overall objective.
Message 12 of 14
(762 Views)
200 cases would be a NIGHTMARE. This sounds like a one-vi-does-everything approach which I promise, is not a good way to do things. If possible, break the code up, keeping similar cases confined to the same VIs, but don't cram it all in one.
Message 13 of 14
(754 Views)
This possibly could be a case for a polymorphic VI.
Message 14 of 14
(736 Views)
