converting an engineering string to a general number
Hi everyone,
Does any know how to convert an engineering string to a normal formated string?
Message 1 of 12
(6,862 Views)
What do you mean by an "engineering string"?  What is a "normal formatted string"?
Perhaps you can give us an example of what the string looks like now and what you want it to look like.
Message 2 of 12
(6,854 Views)
The engineering string outputs a number in sicentific notation (1.10E-01), where we would like to display the number as -.11.  However, this only seems to occur when the number is exported to Excel and when it is close to zero (within a fration of 1).
Message 3 of 12
(6,850 Views)
Do you mean Fractional / Exp to numeric Function?  which is located under the strings palette.. under String / Number Conversion.
Fract/Exp String To Number
Interprets the characters 0 through 9, plus, minus, e, E, and the decimal point (usually period) in string starting at offset as a floating-point number in engineering notation, exponential, or fractional format and returns it in number. The connector pane displays the default data types for this polymorphic function.
Message 4 of 12
(6,849 Views)
Example using Ray's function.  One is an actual number, the second converts that number back to a string with default precision of 6.
Message Edited by Ravens Fan on 06-10-2009 02:42 PM
Message 5 of 12
(6,846 Views)
Is there any way to do this with multiple 1-D array inputs?
Message 6 of 12
(6,841 Views)
Hi nem,
the functions shown by RavesFan also accept array inputs...
Message 7 of 12
(6,838 Views)
Attached is the part of the vi  that write the data to a .txt file which is then opened in Excel, However CH2-01 in Excel reads a scientific notation format.  Trying what was said didn't work due to different source and sink types.
Message 8 of 12
(6,831 Views)
Accepted by topic author nem
Hi nem,
in your vi there is no "CH2-01". Do you mean "DAQ21"?
See attachment for some minor changes (removed sequence, locals, build path a better way). Why do you split your arrays into 4 parts when you need to re-build all arrays again?
Are you sure it's not an Excel formatting problem? Did you set all numbers in the excel sheet to display as "numbers"?
When I try your vi I don't get any numbers in scientific format in Excel. (And I would suggest to transpose the data for Excel import...)
Message 9 of 12
(6,815 Views)
Thanks for your help and suggestions on the block diagram, it was much appreciated.
Message 10 of 12
(6,810 Views)
