converting C code file into .lsb
hey how can i convert my C code into .lsb  so that i can place it in CIN ,what are the tools or software used to do this and steps involved
regards
(3,058 Views)
Checkout the following links below
How to build a CIN code resource (.lsb file)
Using External Code in LabVIEW manual (Chapter 3 CINs, page 63)
Tunde
(3,027 Views)
The CIN is not the recomended method. You should create a dll from the C code and use the Call Library Function Node. There is information in the on-line help. Look up the topics under Shared Libraries. You can also look here [broken link removed]. If you have LabVIEW 7 or older, there is a shipping document on calling external code in the Hlpe>Search the LabVIEW bookshelf and also available here.
Message Edited by Dennis Knutson on 05-14-2007 09:53 AM
(3,027 Views)
