converting 1d array to image
I hope the txt I received was saved just so I could get the data. Because it take some time to read it, and if speed is an issue ;). But anyway the conversion is simple and quick.
Good luck
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 25
(2,727 Views)
Thanks the help ,, your support has been of tremendous help.....
But the image obtained is still monochrome ....am not able to get the color picture...
regards
Rahul
Message 12 of 25
(2,683 Views)
The image is gray because I used a grayscale color table. Change the colortable and you will se colors
Message 13 of 25
(2,676 Views)
I am not able to use the color tables to create the original color of the image and how do i get the color table of my picture..
pls reply
Message 14 of 25
(2,664 Views)
The Reshape array function of converting 1d array pixel information (1228800 elements) to 2d is working fine ,but the conversion time is 350ms while the desired value is around 30ms . so suuggest a way to reduce the conversion time.
pls reply
Message 15 of 25
(2,632 Views)
I do not think it is the "Reshape array" function is the problem. On my computer I run this 100 times and it took 250 ms. If I skipped the indicator it took 98ms. Try to remove all indicators not strictly needed it may help.
Message Edited by Coq rouge on 05-05-2009 02:39 PM
Message 16 of 25
(2,621 Views)
I am grabbing the image parallely on an activex controller,, Could that be a problem??
there are no other indicators..
Message Edited by siju on 05-05-2009 08:05 AM
Message 17 of 25
(2,614 Views)
Oh yes, and certainly if your image indicator is full scale(1280*960).
Message Edited by Coq rouge on 05-05-2009 03:21 PM
Message 18 of 25
(2,607 Views)
Anyways, Could u suggest an alternative?
Message 19 of 25
(2,598 Views)
Sorry I do not have any clue, and besides I have never used VISION. But you could perhaps start new thread and ask for code optimazion help in your project
Message 20 of 25
(2,590 Views)
