convert word to html
Im having an application,where im genreating my reports in word.The information i require here is,
Is there a way to convert my word document to HTML format .(I know i can directly generate it HTML,But im doing some data calculation on my report in word.so I would prefer once my work is done,i can convert the word file to HTML format.)
Also the reason i require,i will  be having option for me to have in word as well as HTML.
if any suggestions,it is helpful.
-Murali
(3,012 Views)
I can see two ways to do this. The easiest way, is to use word to go to File > Save As.  Then save it as a htm.
The second way is using the Report Generation toolkit in LabVIEW.
(3,008 Views)
If the word doc doesn't have any images or complex tables you might try "Save as"  a text file.  That would make it easier to parse the data.
(3,003 Views)
Google "command line wordtohtml". You'll find a few converters. Some work
with the command line, and some are even free. Using the command line, you
can convert a word document to html each time you create a word document.
Wiebe.
(2,986 Views)
