convert to Labview 6
Hello everybody,
I have made a Vi wich couls read measurements and quality faktor from a electronic box.
Can anyone convert this Vi to Labview 6 pleasse.
see attached zip file
Thanks a lot.
Message 1 of 8
(3,787 Views)
It can't be done. I don't know about the express VIs but the DAQ Assistant makes it impossible. The DAQ Assistant uses DAQmx and 6.0 does not support DAQmx. The earliest version with DAQmx support is 7.0.
Message 2 of 8
(3,781 Views)
Thanks a lot,
Could you please replace DAQ with traditionel DAQ ?
I have no idea about traditional DAQ.
Best regards.
Message 3 of 8
(3,772 Views)
You should have the traditional DAQ functions on your palette if you installed it.
There are shipping examples of traditional DAQ that you can use as a reference.
Message 4 of 8
(3,768 Views)
I change DAQ max to traditional DAQ. Can you plesase convert it to labview 6i ?
best regards.
Message 5 of 8
(3,714 Views)
Well, I said I wasn't sure about the Express VIs since I seldom use them and have no reason to down-convert VIs for my own use. None of the Express VIs can be converted to 6.x. What you will have to do is convert the Express VIs to regular VIs by right clicking on them and selecting Open Front Panel. Save the new VIs and then do an application distribution and post the llb.
Message 6 of 8
(3,702 Views)
Thank you very much,
really i never seen anyone who knows like you in labview. everytime when i post you have the answer.
here is the new vi with lbb like you said to do.
best regards
Message 7 of 8
(3,690 Views)
I'm not able to convert to 6.x. What's giving me fits is the dynamic data type that was introduced in LabVIEW 7 and the conversion of the scalars to dynamic data in the express XY chart. I'l continue to work on it but it might take some time and even then, I'm not sure I will be able to get it to work.
Message 8 of 8
(3,675 Views)
