convert string to real
I am working with an instrument to read the internal resistance of motors.  the problem is that I am reading strings and I have to convert them to real.
the Instrument is working that way:
if I have a resistance of 200kohm => 200E3
20 ohm =>20 E0
2mOhm=>2E-3
I used convert to string but its arrounding my numbers.. which is impossible to work with because I need the whole number.
I also used Fract/exp to string buit this is what I am getting
You will find attached my program, please I need your help
(4,609 Views)
Please reduce your VI to a simple example that contains typical strings as a diagram constant. and just includes your conversion and the array indicator. Unless we know how the strings look like exactly, we cannot tell what's wrong. (for example is there really a space inside "20 E0")
(4,592 Views)
This is the exact type of string that I am reading from the instrument
I also tryed yith the function scan from string version with %f but I am having this result
BR
(4,582 Views)
Hi karate,
               Use the attached Vi snippet and the issue will be solved. you have to select Frac/Exp string conversion so that you get the exact resistance value.
The issue is solved
Kudos welcome 🙂
Regards
Santhosh Joel
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(4,567 Views)
Make sure you have the Fract/Exp String To Number setup to NOT use the System Decimal Point.  If appears your localization uses the comma as the decimal point while the instrument uses a period.  Setting that boolean to FALSE will allow you to read the strings with the period decimal point.
(4,556 Views)
