convert string to number
@RavensFan wrote:
It is NOT necessary to add an additional delay in this while loop.  The VISA Read will pace itself.  You will have 10 seconds between VISA reads if no data comes in.  You'll have some unknown amount of time between VISA reads if data is comiing in.  That delay will be a function of how frequently the other device is sending data.
But dont you think after first read and before second read there should be some delay but yes you are right about your last line.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 35
(1,684 Views)
No.
The delay will be there automatically.  If you put in an explicit delay that happens to be too long, then you'll run into a problem where your serial buffer will eventually fill up because you are reading the port slower than the device is sending data.  If you put in a short delay, then you might as well not even bother because the device's rate of sending data and the VISA read is what controls the pace of the loop.
Message 12 of 35
(1,683 Views)
Yes true but if any sender is sending data in 5 sec then after 5th sec while loop will stop and next read starts immediately.Hence next data will come in 5th sec. hence if between two read delay is there then CPU resource will be free for atlease some ms.Isn't it
--Ranjeet
Message 13 of 35
(1,680 Views)
While the VISA read is waiting for the next data to come in 5 seconds later,  the CPU WILL BE FREE to do other work.
Message 14 of 35
(1,676 Views)
But control will be there if you see the highlight execution.it will wait till timeout or 4 bytes
--Ranjeet
Message 15 of 35
(1,673 Views)
What does highlight execution have to do with this?
I don't even know what point you are trying to argue anymore.
Message 16 of 35
(1,664 Views)
If you enable Highlight execution, according to my experience it will wait till timeout or 4 bytes (in this example).
We actually deveiated from question..better we stop it here.
--Ranjeet
Message 17 of 35
(1,662 Views)
As Raven said, the VISA Read will read at it's own pace.  Life goes on while it is waiting for data.  IMHO, hard-coded waits = I don't really understand how to communicate with this particular equipment.  (Usually, but not always.)
[edit]
Funny, I just put together a VI with parallel loops and the lightbulb on, and the other loop was looping while the VISA read was waiting...
Bill
CLD
(Mid-Level minion.)
Message 18 of 35
(1,660 Views)
what is that particular equipment by the way
--Ranjeet
Message 19 of 35
(1,657 Views)
Any equipment, actually - except the most dumbest equipment that won't even tell you when it is ready to receive a new command.
Bill
CLD
(Mid-Level minion.)
Message 20 of 35
(1,654 Views)
