convert read from file string to DBL
hello
I uaed a read from file palette, its output is string. Scan from string output is DBL(64bit precision). I need to change the string to DBL.
someone help me, please
"Thanks with regards "
by
..........Gireesh..........
(2,777 Views)
Why cannot you use the string to number conversion VI, "String to Fractional number" default is DBL here.
(2,767 Views)
'String to Number' perhaps? (functions palette>>programming>>string>>string/number conversion)
Kudos are (always) welcome for the good post. 🙂
(2,765 Views)
