convert parallel to serial
good day sir 🙂 i just want to ask on how to convert parrallel data to serial.. on the vi i have made, the input image is converted to array and then converted to 1-d array of boolean.. my teacher give me a task on how to convert it to serial.. thank you 🙂
Message 1 of 14
(5,321 Views)
Can you explain what do you mean by "convert it to serial" ??
uday
Message 2 of 14
(5,284 Views)
thank you for your reply sir,i want to send these array of pixels to fpga board.. my teacher ask me to send it using digital i/o lines of the fpga.. then he asked me to send it in serial because he says that i have parrallel output.. thats why i'm asking how send that serially..
 at first i thought that i can send the array of pixels in serial because i have just converted it to 1-d array. but im wrong. error occured saying that i have a large amount of lines when sending these pixels to the fpga board. thanks 🙂
Message 3 of 14
(5,266 Views)
You have the 1D Boolean array.  Just write those values, one at a time, out of your single DIO line.
Message 4 of 14
(5,243 Views)
thankyou sir.., 🙂 ahm sir by the way.. how can i write it one at a time? thanks 🙂
Message 5 of 14
(5,236 Views)
Accepted by topic author robin123_hood
FOR loop.  You put the write inside of the FOR loop and you pass the array to the FOR loop.  Use autoindexing and you will be writing out the one value at a time through the entire array.
Message 6 of 14
(5,204 Views)
thank you sir.. 🙂
Message 7 of 14
(5,152 Views)
hi again sir.. ahm how can i reverse the process? because when i wired it outside the for loop and put an indicator,  i cant read any values.. thanks again sir 🙂
Message 8 of 14
(5,122 Views)
Hi hood,
what have you wired? Can you attach your current VI?
Message 9 of 14
(5,116 Views)
here sir 🙂 i cant read any values on the indicator at the top of the loop
Message 10 of 14
(5,109 Views)
