convert hex to float
Give us the exact make and model of the flowmeter. Is there a technical manual that can be downloaded?
Message 11 of 17
(2,276 Views)
The floating number is IEEE-754, 32 bit.
Message 12 of 17
(2,257 Views)
OK, it seems you need to swap words for some reason.
Message 13 of 17
(2,251 Views)
Thank you very much for helping.
It works.
Hong
Message 14 of 17
(2,242 Views)
hi Knight, could you please send me the .vi, i found it was very hard for me to make something like that because i am still learning this in my school
Message 15 of 17
(1,168 Views)
have you read this? It should cover your problem.
Greets, Dave
Message 16 of 17
(1,165 Views)
If you drag the image into your LabVIEW, it should automatically import the code (see https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI for how this works)
The code is not difficult to reproduce. What gives you trouble? The fancy parts are in the Numeric / Data Manipulation Palette: https://labviewwiki.org/wiki/Functions_Palette/Programming/Numeric/Data_Manipulation
Message 17 of 17
(1,138 Views)
