convert from m x n array to array of clusters
I have an M x 4 array of doubles:
Var1
Var2
Var3
Var4
1
2
3
4
5
6
7
8
Want to convert it to:
myNewArray (1D array of)
                myNewCluster (cluster of 1 element)
                                myNewSmallerArray (1D array of)
                                                myNewSmallerCluster (cluster of 4 elements)
        Var1 (double)  Var2 (double)  Var3 (double)   Var4 (double)
by doing this I want to then index through each row. The attached vi has the m x n array and the format of the output
(1,533 Views)
Accepted by topic author kathyleak
I assume this directly relates to your previous question, right?
You did not attach any of your type definitions (there are two!), so I had to disconnect them. You need to substitute the typedefs again.
Try this as general possibility:
(1,516 Views)
You are in fact brilliant! I had disappeared down a rabbit hole building a manually indexing bit of code instead of using the auto indexing. Me thinks me and Rube Goldberg have a lot in common.
(1,484 Views)
