convert .cpp to .vi
          Is there a way to convert written text-based codes like .cpp into .vi?
Thanks.
(3,661 Views)
CIN Help
You can use Code Interface Node in LabVIEW to use cpp code in LabVIEW.
(3,658 Views)
You cannot convert a .cpp file into a VI. There are two possible ways in which you can call external code in LabVIEW.
- You could use Code Interface Nodes (CINs) to access algorithms written in another language. You will need to follow some steps to create a CIN.
Example: Refer to the Multiply using a CIN VI in the labview\examples\cins\mult
- The other common and most used method is to create DLLs in the programming environment and then call those DLLs in LabVIEW using the Call Library Function Node.
Example: Refer to the Call DLL VI in the labview\examples\dll\data passing\Call Native Code.llb
If you have any questions, be sure to search on the NI website or post back.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,655 Views)
Is this related to this thread?
What exactly you want. Post in specific and also give bit more details in what trouble you are facing. That will help us in guiding you better.
Mathan
(3,654 Views)
Hi Mathan,
                 I have written a programme in C++. I am thinking of creating a GUI for this programme using Labview. I have done previously using Visual C++. I would like to know how I can do it using Labview.
Thanks.
(3,651 Views)
Please go through all the links in AdnanZ post and post if you are facing any problems. Try to start writing in your own first and post immediately if you stuckup on anything.
(3,647 Views)
