convert ascii string to hex string
I'm having trouble converting an ascii string to a hex string and parse.  For example, if the input string is EQ36 (length = 4) the output string should be 45513336 (length 8).  Any suggestions how this conversion can be done?  Thanks in advance.
(9,724 Views)
Hi, this should do it.
Greets, dave
Message Edited by daveTW on 06-30-2008 02:12 PM
Greets, Dave
(9,721 Views)
If it is only a "display-thing", there is an even simpler solution!
Just display the string in a string indicator and set it as "Hex-display"....
hope this helps,
Norbert
Norbert
Expert: Geometry
(9,714 Views)
Thanks a bunch, worked perfectly!
(9,713 Views)
