convert an U16 array to a defined cluster structure
I have a telemetry data sream in I16 format which is stored in an I16 array.
The data in the I16 array represent parameters of different test steps. The test steps will be handeled in different VI's. Each VI has to now where it could find its relevant data within the I16 array. So if a VI load its data it has to now the start ID within the array.
My problem is, the TM Packet format changes (in my experience) during the project livetime serveral times, therefore the start ID's change.
My idea was like in 'C' to define a global structure type common for all VI's and cast the I16 array to that structure type.
I tried several experiments with I16 array to cluster casts but until now not successful.
I
hope i descibed my problem passably.
I am thankful for any solution.
Peter
(2,910 Views)
Please explain in more detail the information stored in the I16 array.
I would suggest to cast the I16 array to a string, and convert from there.
Hope this helps, Oskar
(2,910 Views)
> array.
> now not successful.
> I hope i descibed my pr
oblem passably.
> Peter
You need hash table. The value and a key. Array index could be the key
to desired element (parameter). Did you tried incapsulate this into
vi-global (while loop with uninitialized shift registers for array
itself and array of indexes)? Goop scheme uses similar way of
manipulating complex data objects incapsulated inside repository vi.
This is described in "LabVIEW Power programming" book by Gary Johnson.
and in GOOP documents. The all available from www.ni.com, search for them.
Clusters seems not the thing to reach your goal.
This is just an idea if I'm not missing something.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(2,910 Views)
