convert Labview 5.1 programme to Labview 7.0
I want to convert a Labview 5.1 programme to any Labview version later than that (Labview 6.0, Labview6.1, Labview7.0, Labview8.0, Labview8.2). All you have to do is open it in the new version and save it in that format (I have Labview 8.5 and I can't open it in it).
Thanks.
Message 1 of 12
(7,067 Views)
Yes, you need a version older than 8.5 to open a 5.0 VI.
Don't know why you posted this question. No one can help unless you post the VI you want converted.
Message 2 of 12
(7,063 Views)
Thanks for the reply.
Sorry, I forgot to post the VI. Here is the VI.
Message 3 of 12
(7,059 Views)
When I opened this VI, there were two errors due to missing VIs.  One was "Serial Read with Timeout" (which I might not have installed on this machine, but you probably have on yours), the other was "Pressure1", which I presume you already have.
This was opened with LabVIEW 7.0, and then saved.
Message 4 of 12
(7,045 Views)
You will also want to consult the upgrade notes when upgrading a VI to see what known issues you may encounter on the upgrade:
http://www.ni.com/pdf/manuals/321780f.pdf
-Bob
Message 5 of 12
(7,038 Views)
Thanks Bob. I will check and let you know whether it worked.
Message 6 of 12
(7,035 Views)
I am still getting error with the previous VI. So I need to convert this sub to Labview 7.0 or any other version earlier than 8.5.
Thanks so much...
Message 7 of 12
(6,966 Views)
I want to convert old VI of Labview 5.1 to Labview7.0 or/and  Labview8.2
Thanks.
Message 8 of 12
(6,690 Views)
Hi PHM,
I tried opening your VIs in LabVIEW 8.2 but apparently they were not saved with a block diagram. Do you have a version of the VIs with block diagrams? Without them it will be impossible to upgrade.
Take care!
Tanya Visser
LabVIEW Group Manager
Message 9 of 12
(6,645 Views)
Please post in the Upconvert Requests Thread (assuming you have the VIs with the block diagram). That thread is monitored more closely.
Thanks.
Message 10 of 12
(6,638 Views)
