convert 2d array to 1d array without using shift registers and build array
hi
I want to convert 2d array to 1d array without using shift registers and build array. Basically, i want to reduce the overhead involved in using the build array.
(3,316 Views)
Have you tried "reshape array" function?
(3,315 Views)
Hi
Thanks for the suggesstion, i tried it and it works as i expected.
bye
(3,315 Views)
Index Array will also slice out either a row or column.
(3,315 Views)
