convert 1D string array to 2D array
conversion from string to number is not that important, I can do it later. My problem is right now how to split the string( every 8 chars or every 4 chars) and insert them in the next columns ( the same row). Can you help me to do this?
I tried using split string but then how can I move it to the next cube?
Message 11 of 16
(2,284 Views)
Post what you've done and we'll discuss.
Message 12 of 16
(2,281 Views)
You can use String Subset to get the characters you need and then Replace Array Subset to write that substring into the location you want it.
Message 13 of 16
(2,264 Views)
Hi
I need to display an array of strings obtained from a loop. I tried to tabulate it but that requires a 2D array. Now i have no idea how to convert it into 2 dimensional string array, please help
thankyou 🙂
nivi
Message 14 of 16
(2,209 Views)
Use Build Array with just 1 element.  You may need to use Transpose 2D Array to get it to show up in your table the way you want.
Message 15 of 16
(2,192 Views)
Yup, both build array and transpose solved it. 🙂
Thanks a lot
nivi
Message 16 of 16
(2,185 Views)
