conversion of time format
conversion of string indicators containing 12Hour -time format into 24hour-time format
ie  1:35:00 pm(12hour time-format)  to  13:35:00(24-hour format)
Message 1 of 9
(4,590 Views)
I'm not sure what your question is but if you want 24 hour display just open the indicator properties and change it on the Display Format tab.
P.S.  Please avoid .docx format for posting.  They can contain viruses and many won't open them.  Just post a picture, or better, your VI.  Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 9
(4,580 Views)
First off DO NOT paste a picture into a Word document then attach the document. Use the Insert Image function the forum has.
Also I am not sure exactly what you are asking. But here is how to format a time stamp into 12 and 24 hour time strings
=== Engineer Ambiguously ===
Message 3 of 9
(4,575 Views)
I highly recommend giving the LabVIEW help a good read.
Format Specifier Syntax
Format Codes for the Time Format String
Message 4 of 9
(4,571 Views)
actually i have taken a numeric control of time- date format in which display format of time is 24-hour type but the requirement is that the numeric control should be converted into string type in which display format is 24-hour type.
how to achieve this?
Message 5 of 9
(4,539 Views)
Have you even bothered to read the thread that you created?
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(4,526 Views)
The two posts from RTSLVU and crossrulz right above have already specified the answer.  Use the Format Date/Time String VI.  Learn how to set the format string to get the desired text output by looking at the help or reading the links above.
Message 7 of 9
(4,508 Views)
Read the two attached docuents from LabView Help
Message 8 of 9
(4,500 Views)
You have two options: Format Date/Time String or Format String.  I prefer Format String since I am usually combining other things.  For the format string, follow formats given in the LabVIEW Help (follow the links I already gave you).
Message 9 of 9
(4,475 Views)
