conversion of hexadecimal file to decimal file in labview
hi all,
I took a measurement from an anemometer by its original program. I attached the file below. I want to convert this file to the decimal file. I all know is the data in file are in hexadecimal and 16-byte. How can I convert this file to decimal one? I prepared something as I saw in this forum but it gives me just one number. I attached the vi below too.
Egemen
Message 1 of 32
(5,722 Views)
Hi ,
Refer this,
Bijay
Message 2 of 32
(5,709 Views)
@newbieeng wrote:
hi all,
Do you mean 16-bit? Signed or unsigned?
For posted example: Reading the file as string and then converting to numbers is the wrong approach. It requires extra memory to create the strings and then to convert to numbers.
All you need is a single Read Binary File, with the appropriate data type set.
Message 3 of 32
(5,702 Views)
Hi newbie,
it doesn't make sense to convert the filename to some other datatypes. You have to load the datafile first!
@Bijay: as the file is no spreadsheetfile it doesn't make sense to load it using ReadFromSpreadsheetFile!
You may try this:
The file seems to contain SGL values so I typecasted them. If that's not the case you use the U8 array to do your own computations...
Edit:
Using ReadBinaryfile is somewhat easier...
"the data in file are in hexadecimal and 16-byte."
The file isn't in hexadecimal, it's just binary. And what do you mean by "16-byte"???
Message 4 of 32
(5,693 Views)
@smercurio_fc wrote:
@newbieeng wrote:
hi all,
the data is 16-bit unsigned. I wrote 16-byte wrongly. sorry for that.
Egemen
Message 5 of 32
(5,692 Views)
Then simply change the data type from I16 to U16.
Message 6 of 32
(5,685 Views)
Thanks for feedback GerdW.
Bijay
Message 7 of 32
(5,684 Views)
@GerdW wrote:
Hi newbie,
You may try this:
Edit:
I wrote it wrongly. It must be 16-bit. It must be in hexadecimal. The manual of the program that I took this data file says the output is in hexadecimal format.
Egemen
Message 8 of 32
(5,678 Views)
Message 9 of 32
(5,659 Views)
@GerdW wrote:
Hi newbie,
You may try this:
Edit:
I tried your suggestion and find something what I really do not know what they are. I attached the results print screen. I will try the second solution.
Egemen
Message 10 of 32
(5,654 Views)
