conver image to RGB chanel then add noise. how to add noise? HELP plz
i am working on adding noise to the image that i uploaded on labview i added the picture then transfer it to RGB channel.
my concern that i want to add noise to  RGB channel. i couldnt do that and i uploaded some of what i did and if someone can show me or help me how to do it ?
will be so  glad
(4,140 Views)
Hi never...,
have you read this thread recently appeared from the past? Here you could read how to (correctly) separate color channels...
To add noise you have to add to the image data itself, but not to the color table! You can add to the entire image data or after separation, to just one color channel...
(4,119 Views)
thx man and i did add the noise and seprate to RGB but now i got stock compaining all three RGB together so i can get the origianl imag with the noise
any advise 😞
(4,114 Views)
Hi never...,
you put the image back into that cluster the same way you unbundled it: Simply replace the "image" component of the image cluster...
(4,093 Views)
