controlling numeric slider with numeric control
what i have is a numeric slider and a numeric control.  i would like to be able to move the slider and have it update the value in the numeric control and vice versa.  the problem is that i can update the value in the numeric control when i move the slider, but i can't update the slider if i try to change the value in the numeric control.  i was trying to use the 'value' property node for each of them and and wire each of the controls to the opposite property node.  i know they are both control but i thought if i change the 'value' to an input then it may update.
i have attached the vi.
thank you
Message 1 of 11
(10,016 Views)
RIght-click your slider and select "visible items...digital display". 😄
No code needed!
Message 2 of 11
(10,011 Views)
You have a classic race condition. Don't just put them in a while loop, use an event structure with value change event for the slider and another value change event for the numeric.
Message 3 of 11
(10,008 Views)
Here's how you could do it if you really need seperate controls.
Message 4 of 11
(10,004 Views)
makes sense,
thank you
Message 5 of 11
(9,997 Views)
Since this numeric_slider VI uses an event structure, it only outputs a value when the slider or the numeric control are modified. I need it to continuously output the numeric and slider control value, even if no changes are currently being made to the control value.
My while loop just pauses until I move the slider back and forth. I've tried a lot of things and worked on this for hours and I'm still stuck.
Any help or insight would be appreciated beyond measure!
-Adam
Message 6 of 11
(9,540 Views)
Adam, this is Paul with Applications Engineering at NI.
I was unable to open your attached VI because it was missing simplepid.vi.  I glanced at the rest of your code, but it looks like that might be the meat and potatoes of what you're trying to accomplish.  Try putting your files into a project, then zipping them up and posting them, and we can see what we can do for you.
Paul
Paul Davidson
Product Owner - ni.com Chat
Message 7 of 11
(9,514 Views)
Well, since the event structure only executes when one of the controls changes, it is blocking the loop. Dataflow in action!
A quick solution would be to make the event structure "transparent" by adding a short and empty timeout case. Now just use a feedback node to retain the existing value if the controls did not change.
There are probably definitely better ways to do this, but they would require more fundamental changes to your code.
Message 8 of 11
(9,511 Views)
Thanks! Works like a charm and makes good sense...
One last thing, there's one slider and TWO numeric controls to set the P-term. I would like to delete one of those numeric controls to avoid redundancy, but they seem interdependent.
I can't remove one of them without causing errors I can't figure out how to resolve...
Thanks again for the help on this,
-Adam
Message 9 of 11
(9,496 Views)
You need to remove the one on the right, the other one belongs to the slide. since there is now only one source, you don't even need the event structure.
Makes sense?
Message 10 of 11
(9,479 Views)
