controlling AC TRIAC circuit with LabView and Arduino
Things would be a lot sampler if my company would upgrade my LabView 8.6 to a newer version. I built a circuit that control the phase angle of a triac and using an Uno Arduino board. the circuit works great with a pot but I would like to use Labview to control the circuit. I can get the power to go from low to 120AC with Labview but when I move the slider to change the output the voltage is not linear it jumps around until you stop moving the slide bar. I try differrent ways to see if I can smooth the voltage out but not having any luck. I included the vi of the closet code that works. Hope someone will give me pointers to improve it.
John
(2,577 Views)
Try removing the wait on the outer for loop. The event structure is waiting on the value change anyway so the wait is redundant.
Also, is there a reason you're using a slider to change the values? Would it be possible to change it to a simple control to have the value only change once to the desired value?
(2,543 Views)
I want to use the slider to control the Triac. I did get it to work by doing the math differrent.
Thanks for your suggetion.
(2,531 Views)
