controller axes movement
hi,
       In my project i have a controller with 3 axes movement.Whenever i run my vi,there is a screen called LSlogView getting opened up each time,which i should hide it when i give it to my end user. Is there any possibility to stop that screen getting projected.
(2,322 Views)
you can change the property of the projected vi to run minimised condition in vi properties, window run time position and selet the position to run minimised. As a result it will not be poped up but it will be in the taskbar and it can be opened by clicking on it..
LV 8.0, 8.6, 2011,2012,2013 WinXP
(2,321 Views)
