controlled timer
I need to install a timer that will allow the user to: choose with a control how long they want that program to run for and go onto the next when the timer has ended.
I have a case structure with 3 cases and so I don't want to be using a while loop.
thanks!
Message 1 of 16
(4,988 Views)
Any program this is going to run for awhile is going to need a "while" loop.  So I don't understand your statement "so I don't want to be using a while loop".
Please attach your VI.
Is it related to this thread?  skipping first step of array.
If is as heavily related to that thread as I think it is, then I suggest sticking to that thread with your question.
Message 2 of 16
(4,984 Views)
It is related to that thread, but if I put a while loop in, then the start.vi stops and starts instead of a smooth infusion or withdraw.
Message 3 of 16
(4,977 Views)
Message 4 of 16
(4,976 Views)
That's ridiculous. You want the wait to happen after the pump is programmed, correct? Then why would you create a separate state? The wait has to go after. You can use a simple Delay function. That would not allow you to interupt the wait, however. If you need that, then you would need a different design.
Message 5 of 16
(4,967 Views)
I want the pump to run for a certain amount of time which is defined by the user. I don't know what you referring to.
Message 6 of 16
(4,962 Views)
It's probably not smooth because you are reinitializing your VISA resource on every loop iteration.
What you need is a state machine.  The key states would be Initialize, Execute a step, wait, Close.  The wait statement is where you put your timer.  You can either return to the wait state if the time is not up, or go back to the Execute Step state if the timer is up and execute the next step out of your array.   All of this is in one while loop.
Message 7 of 16
(4,960 Views)
Can I furnish a state machine with the layout that I have now or should I restart?
Message 8 of 16
(4,956 Views)
That does not surprise me.
Message 9 of 16
(4,955 Views)
What?
Message 10 of 16
(4,949 Views)
