controling the cursor position
Hi all,
I have two x, and y signal outputs from a dll module and I plan to use them to control the cursor position. One problem I'm facing is that my signals are variable enough to cause the cursor to vibrate in stationary setting. So, I use hysterysis (putting threshold) to eliminate these fluctuations but the drawback is that keeping the treshold high enough to eliminate the fluctuations keeps me from getting a nice, smooth movement when the speed of movement (rate of x and y changing) is low. Any ideas or suggestions will be appreciated.
p.s. I am using "SetCursorPos".dll as you might have already guessed.
Thank you,
Elnaz
(2,712 Views)
I would suggest a simple exponential average with a low degree, it acts as a low pass filter.
(2,706 Views)
Actually, I just realized that the vibration is pure sensor noise (magneto-resistive sensors whose data are used to calculate X and Y signals). This changes the body of the question a little bit:
How to cancel out sensor noise (high frequency vibrations) from actual data which can also be high frequency ? Because If I filter the noise out that will affect the sensitivity of the cursor position produced by the real data as well.
(2,699 Views)
Darin,
Could you please clarify what do you mean by average exponential with low degree? Can it be applied online?
(2,688 Views)
The formula for an exponential filter of degree D is the following:
New Average = (New Value + (D-1)*Old Average)/D
I usually add a special case for startup so that D is never greater than the number of points.
As I said, it is a low-pass filter, much like using a running average.  I usually like it because the state is simply a single value (Old Average) instead of the array of values you have to keep around to do a running average.
As to the new question of separating high-frequency noise from your high-frequency signal, that is a bit more complicated (obviously).  You should take a power spectrum of the noise to see if there is a characteristic feature you can use (cutoff frequency, strong peaks).
(2,685 Views)
