control to subvi
I am trying to send a numeric control input to a sub vi.  going from other examples I have created a reference (digital) in the main vi.  then i create a control refnum in the sub vi.  but i cant figure out the proper way to connect this to a property node of the control input in the sub vi.  their types are different, and unlike in the examples i have found there is no wire for ref input?
(2,786 Views)
Right-click on the reference in the main VI and select "Create Control". Copy that control onto the subVI's front panel. In the subVI, place a property node from the "Application Control" palette. Or if you already have a strict property node, right click it and select "Disconnect from control".
(2,774 Views)
Connect the control refnum in the sub vi to a property node and choose "Value". This will get you a numeric output.
(2,760 Views)
(2,760 Views)
