control the order of plots
Cameron,
Now I have run your VI. It is ingenious and I wouldn't have thought of it.  However, it does not do what I was seeking, because it DOES change the order of array elements going in to the plot.  In your VI, the white "plot 0" is always in front. It is easier to see this if you make the lines really thick. But the data being plotted as "plot 0" keeps changing in your VI.  If the labels really meant something (such as position, velocity, acceleration) then I'd also have to change the plot labels each time I change the plot order, with your VI, to keep the labels correct.  That could be done with property nodes, but it would get complicated.
Thanks for your help.
Bill
Message 11 of 19
(1,725 Views)
Oh, but you haven't run my optimized VI, which is in my last post. It does, I think, what you want, with the possible exception of keeping the top right legends in a consistent order (they are right, however). The property node thing for swapping colors around is no big deal - you just have to wire it exactly backwards of the plot ordering wires. It's all there.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 12 of 19
(1,723 Views)
Cameron: I am impressed.  Your new and improved VI keeps the labels and colors associated with each data set, as the order is altered. It would be nice if one could just click on a trace and select "Move forward" or "Move backward".  But we can't, and you have provided an alternative method. Thank you.
Message 13 of 19
(1,716 Views)
Oh, you could, but I didn't.That's the situation which an author would "leave as an exercise to the reader". A drag-and-drop control might also be fun to use there, but I don't have any experience with those (check back in a month or so, that's the next thing I have to implement in my UI's).
You know, probably a better way than using an enum on that would be to use a ring control, because you can get a drop-down listing of all the possibilities (at least the ones you included in the ring) to choose from, instead of having to cycle through them one at a time.
Cameron
Message 14 of 19
(1,706 Views)
Hi Cameron,
you don't have to "cycle through" an enum, you can also select from a list of entries here.
Using drag&drop is very easy with a listbox, it has that feature built-in - just check the settings with a right-click...
Message 15 of 19
(1,702 Views)
Thanks, Gerd, it'll be nice if something in LV is easy right-out-of-the-box (and I'm not including Express VI's in that category) for a self-taught programmer (although I did take Core1 and 2 when I had the chance - they were invaluable).
Cameron
Message 16 of 19
(1,700 Views)
Your last example does work a whole lot better.
It still proves that Jeff was right, and that you can't do this without changing the order of the plots in the legend, which is was what the OP did not want to do.
But your idea of creating a static legend would be one way of making it appear that the order as not been changed.  It's not ideal.  And you lose the ability to do some things that are built into LabVIEW such as change plot visibility unless you want to do a whole lot more programming.
Message 17 of 19
(1,692 Views)
Those are good points, RavensFan.
Message 18 of 19
(1,688 Views)
Thanks, RF.
But, as far as my "static legend" workaround being "not ideal," Sure, I know it isn't, but I don't think I've ever done an "ideal" thing in my life. It's just a workaround to present an example of what you could do if that's the kind of thing Bill was looking for. I just look at the legend as a quick way to identify the specific plots, and that, to me, would be the quickest to follow.
Besides, I'm still on a pretty steep part of the LV learning curve, a lot more climbing to go.
Cameron
Message 19 of 19
(1,681 Views)
