control the array shell size in running
Dear,
My data will be presented in an array.
The size of array could be changed depending on a user.
However, I would like to control the array shell size to the real size of the arry as shown in attachment.
Is it possible to control the shell arry to fit correctly (with/without scrolling bar)?
(I couldn't find out the function)
메시지가 04-02-2007 07:05 PM에 labmaster에 의해 편집되었음
(3,411 Views)
You have your data in a Table. And yes, you can control the number of rows or columns. You use a property node. Right click on the the indicator and select Create Property Node. Right click on the property node and select Change to Write. Right click on it again and select Properties>Number of Columns.
(3,391 Views)
Although I found the properties, I didn't try it because of misunderstanding the meaning.
Thank you very much.
(3,387 Views)
What is it that you don't understand. Will a picture help?
Message Edited by Dennis Knutson on 04-02-2007 09:03 PM
(3,385 Views)
Thank you for your kindness.
I would like to ask one more question on array.
Is it possible to make an array which has an auto-scrolling option?
I mean the number of row is big so that I can't see the data in a monitor.
(3,372 Views)
I found the solution!!~~ is it index value?
(3,369 Views)
