control temperature using USB6221
i have a USB 6221, i m a beginer, so i have a project control temperature by PID, in project i have to control the light 220VAC to change the temperatute, i used moc 3020 anf BTA12, but i can not control it, i have a problem that i can't catch the the zero point phase , any body can help me, i want to catch the zero point by labview using USB6221
(3,253 Views)
Have you written any LabVIEW code for this yet? If so, please attach your code so that we can see what you have done to help you out.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,228 Views)
im a beginer. so i can't write it. if u have a example about ít , can u share me, im so grateful
(3,214 Views)
now, i want to measure the temperature by lm35, i can do it, and i can't create PWM signal to control the light 220AC, u can have me to sold this problem, create pulse PWM control the light 220AC, i search example in the internet but not useful. u Can have me, and control PID .
(3,208 Views)
Thienbinh,
On the ni.com website, there is a Controls Tutorial which I think will help you get started:
http://zone.ni.com/devzone/cda/tut/p/id/6368
Also, I found this example on PID PWM control by searching ni.com for "PWM" and clicking on "Examples" in the left-hand column.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:ex/q/pwm/
If you have the PID toolkit, you can also find examples by going opening up LabVIEW and selecting Help>>Find Examples...
Hope that helps!
(3,194 Views)
