control property node, value not updated
I have weird error.  I use a control to send a value to a compact RIO. This value is send and then updated through a property node. This worked fine but it seems to reset to a fixed value.. I can see that the correct value is send to the property node but it is not updated to the correct value.. If I fill in a value over 100 it resets to 100 while with the probe I can see that 101 is send to the property node..
(3,212 Views)
There must be something else writing to your control.  Can you supply your code?
(3,191 Views)
Thanks for the response! After some investigation I found that the display was set to a floating point representation of 1 digit. So I think it only showed the first digit. When it showed 100 the value was 101.
(3,179 Views)
