> Im currently working on somthing that requires me to control the
> locations of many/unknown number of cursors on an xy graph. I can
> control up to 9 so far (0-8), but in the block diagram when I unbundle
> the CrsList Property of the XY graph, I can only go as far as
> 08.Location, and then just stops and wont even start listing cursor
> 09. I have LabView 6.1 right now, if this has changed in 7, please let
> me know, or if not, if there is a way around this problem.
It sounds like you are casting the LV array of cursors to a cluster and
using unbundle by name to access them. Problem is that the array to
cluster convertor has to create the same size cluster each time and
defaults to nine elements.
If you want to change this to a larger number,
right click on the
convertor and change it to a larger constant. If you want it to be
completely dynamic, don't convert and work on the array instead.
Greg McKaskle
