control keypad from labview
I would like to connect a keypad 4x4 and monitor it from Labview.
In the past I implemented a simple algorithm which scans the rows and coloumns of the matrix, but is there an easier way to do this in Labview?
I don't mean a virtual keypad, but an actual one. I would like to use Crio with RT as my controller
Eyal.
(3,055 Views)
Hi Braxat.  WHy don't you use the parallel port of your computer?  it's a mini-DIO port.  Just to give you an idea.
To just read a keypad, it's a really expensive solution to use c-Rio
Kind regards,
BJorn Conjaerts
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,032 Views)
I won't have a PC for this instrument, but it will be an autonomous testing equipment.
Monitoring the keypad is just a feature I need to add to this instrument, so I can't have shortcuts. I hoped an elegant solution already available in Labview existed, but maybe I'll have to use 8 channels DIO module for scanning the keypad.
If there is a nicer solution I'll be happy to hear about it :).
Eyal.
(3,025 Views)
