control for case structure
If you have True and False, what do you expect the third case to be?  KindOfTrue?
The names you use in the case structure are dependent on the datatype you are wiring to the selector node.
EDIT:  I started typing but got sidetracked by my job before I could post.
Message Edited by Ravens Fan on 07-08-2009 03:42 PM
Message 11 of 14
(1,429 Views)
GerdW,
I have never used an enum before but what you have does make sense.  I replaced the constants you had with an enum control and it works perfectly now.
Thanks for the help!
Message 12 of 14
(1,420 Views)
Hello, How to connect the Enum Control to the Case selector? As I have already connected Enum to case selector so it is not accepting my Enum control over that. Can I use either one? I mean just the Enum control without Enum as the case selector Control?
Thank you.
Message 13 of 14
(1,246 Views)
Hi Mohit,
you can replace your enum constant by an enum control…
Message 14 of 14
(1,245 Views)
