control different front panels
Is is possible to open 6 different windows from within a master program by using the call by reference function.If not is there any way at all to do this?
(2,526 Views)
If what you want is to run the VIs independently, then instead of using call by reference, use the open VI reference, the FP.Open property, and then the Run VI method with Wait Until Done set to false. There's a very simple example here that you should look at.
(2,526 Views)
