contiuous voltage input, regulate voltage
When I run my system it goes over the +-10V voltage range. Accordingly, I would like to configure a circuit to lower the voltage output. In the circuit configuration, can I connect the ground part to AI- and make it differential? Or maybe there is another way?
If you know a way to lower the circuit or output voltage, please let me know.
When I configure the circuit, I don't know exactly how to connect it to the DAQ.
thank you
(1,141 Views)
Hi ssfed,
  • Which "circuit" are you talking about?
  • Why does your "system fo over ±10V"?
  • How do DAQ and "AI-" come into play? Why should that  ground connection make something differential?
You really need to describe your problem with more details and information!
To answer your question (literally): use voltage dividers or Z diodes…
(1,129 Views)
Do you know why the voltage exceeds +-10V and looks like a square pulse? Is this a circuit problem or is it out of measurement range?
(1,131 Views)
I would like to know why the voltage drops to about -11V when the system is not running.
Is it a calibration problem in the system?
When the system is not operating, the voltage moves slowly from -11V to near 0V.
Could it be a grounding issue in the circuit?
(1,125 Views)
What hardware are you using to generate this signal? how about the software used to control this hardware?
Santhosh
Soliton Technologies
(1,111 Views)
Duplicated with voltage calibration?
https://tmesystems.net/
(1,102 Views)
