continuous sinewave signal
hi,i need to generate a continuous sinewave signal which have amplitude and frequency continuously variable (without stopping the output generation),may you help me?thanks
Message 1 of 8
(6,159 Views)
I have found no place where you can change the amplitude.  Attached is an example of changing the frequency.  You can vary the desired frequency while it is running.  LV7.1
Message Edited by rpursley8 on 12-07-2005 02:10 PM
Randall Pursley
Message 2 of 8
(6,145 Views)
Sorry but i haven't the labview 7.1.i can use only 6.1-7 labview versions.
may you send me an aqual example for one of these labview versions?
regards,
Mauro
Message 3 of 8
(6,116 Views)
Hi Mauro,
Just go to labview examples and you will find a VI called "Function generator.VI" (or got to search tab and type this name to find it)
This Vi will not only generate the selected function but also permits you to change the type of signal, its amplitude, frequency, offset, phase etc on the fly( without stopping the VI)
Hope this helps
Dev
Message 4 of 8
(6,112 Views)
Here is the VI i have spoken about in previous post
In LabVIEW 7.0
Message 5 of 8
(6,109 Views)
Here is a copy as LV7.0
Randall Pursley
Message 6 of 8
(6,102 Views)
I am using Realtime frequency.vi for LabVIEW 7.1...It works great, but how can I make it so the amplitude is continuously variable as well?  Thanks!
Message 7 of 8
(5,877 Views)
There is no way that I know of.
Randall Pursley
Message 8 of 8
(5,872 Views)
