continuous read.vi
I have thid vi for continous data read from keithly 26XX. It is not saving any data in the file. I am unable find the error. Can anyone help me?
Sudipta
(3,698 Views)
Have you tried SourceMeter2600 with the various Options in a "reasonable" order, and do they work without giving you errors?  This will tell you (as I'm sure you know) if your GPIB command syntax is correct.
The problem with Continuous Read include:
  • You only have a call to the Read function, but no initialization or finalization code.
  • You have a File Open/Create within the loop, which means that you are trying to open the file for every point.  Put it outside the loop and bring the file reference (thin green wire) into the loop for the Write to Text File function to use.  When you exit the loop, bring the reference out and close the file.  You are also writing the entire file each time through the loop.  If you initialize outside, then inside the loop, you only need to write the latest value(s).
  • When you concatenate your strings, are you including any spaces or line breaks, or are all the numbers just running together with no way to tell when one number ends and the next one starts?
(3,687 Views)
You are opening the file again and again on every loop iteration.  Move the open file VI to before the loop and pass the reference in through a tunnel.  Also put a close file VI behind the loop so it closes the resource after the loop ends.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,682 Views)
Bob,
IUs this what you asked me to modify? May be I am still missing something. I tried to follow your instruction and modified continuos read.vi file
Please have a look and suggest
(3,629 Views)
NIquist
I have tried as you suggested. But where do I put close vi behind lop?
Please have qa look in the program once
(3,626 Views)
560092 wrote:  But where do I put close vi behind lop?
This is a typical setup for a write to disk setup.
(3,603 Views)
