continuous binary save then convert to spreadsheet
I'm trying to continuously save time stamps to a binary file on every iteration of a while loop, and then when the code is stopped I would like that file to be converter to a csv file.  I'm having trouble implementing this, could someone point out where I'm going wrong, thanks!TimeToBinary.JPG
(3,550 Views)
Your index/replace isn't working because your array is empty.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,543 Views)
Accepted by topic author Fibo
Check out:  How can I write and read binary files
"prepend array or string size" needs to be = TRUE on the binary write.
I'm not sure why you want to save as a single element 2D array.  Attached is a simplified version.
(3,538 Views)
awesome, that worked.... I was just doing the 2D array thing cause I'm going to have some more data once I get pass this step.
(3,526 Views)
