continually prompted to save changes to vi
hello.
each time i run a vi, i am prompted to save changes to it.
simple search shows the following solution.
http://digital.ni.com/public.nsf/allkb/19C57EBCDDA4B31586256B53007C538B
yet, this does not work when compliling either the library of te file in question (error.llb) or its parent directory.
Here is a screen shot of the messasge.
This is NI labview 8.6
the code happens to be running on a crio 9014 if that matters.
OS vista 64
Any ideas?
(3,209 Views)
Are you using probes?
I've seen this message pop up when I place probes on the BD of a VI running on a cFP target.  I'm not sure why, and it is kind of annoying.
(3,186 Views)
we were using them and there still may be a few probes down.
Ill check it and report back.
Message Edited by jimmyinCT on 09-26-2009 04:58 PM
(3,183 Views)
no, there were no probes in the target.
its really annonying to have to see this everytime we run the program
(3,129 Views)
Are you using any X-Controls? X-Controls have the attribute of whether to save their state or not. If the X-Control is saving its state this can lead to the behavior you are observing.
Message Edited by Mark Yedinak on 09-28-2009 06:55 PM
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,124 Views)
there are no x controls orin the file
Message Edited by jimmyinCT on 09-28-2009 07:04 PM
(3,117 Views)
Its not related to the crio
I found another file which gives similar behavor
The example for "write to spreadsheet.vi", which is titled "email with data"
Also continually prompts me to save this file of which, does not seem to be in use.
This is the only other file which has the same behavior so far
I get hte message regardless of where the vI is run
Message Edited by jimmyinCT on 09-28-2009 07:11 PM
Message Edited by jimmyinCT on 09-28-2009 07:12 PM
(3,112 Views)
