continious loop
On the lower half of stop switches, I want to record just the initial time when the switch closes because it will remain closed for a long time after. I am unsure of how to how to record this initial time because currently the time keeps increasing as long as I hold the switch closed. The first set of switches (start) do not need this same modification. They work correctly. I have attached my current VI.
Thanks so much!
Message 1 of 8
(4,464 Views)
I would suggest taking what the boolean value was on the previous cycle.  Then a case structure stating  current run = previous run, if false then record new value.
Do this for each boolean.  Should work, I've used similar logic in the past.
I'm afraid I dont have time to show you by work on the vi at the moment.  Sorry if I havnt been very clear.
_________________________________________________________________________________________________
That glass?
Thats glass is neither half full or half empty....
Its twice the size it needs to be
Message 2 of 8
(4,454 Views)
I do not understand why you OR the data with an array of False, but that is not relevant to your question.
To detect the change, us a shift register.  When the current value is True and the previous value is False, then record the transition time.
Lynn
Message 3 of 8
(4,453 Views)
Thanks for your quick response!
I'm afraid I'm still confused. Would anyone be able to show we on my VI?? Thanks so much!
Message 4 of 8
(4,450 Views)
Accepted by topic author blizabeth37
I cannot test it because I do not have the DAQ hardware.
Lynn
Message 5 of 8
(4,433 Views)
Awesome!
The only problem is it is opposite. I want to record the intial time when the switch closes and remains closed...right now the time stays constant when the switch intially opens. How do I switch that??
Thanks so much for your help!
Message 6 of 8
(4,422 Views)
I actually just figured it out! I just removed the boolean NOT because it was opposite.
Thank you so much! You were so helpful!
Message 7 of 8
(4,417 Views)
Remember to mark as solved Smiley Happy
That glass?
Message 8 of 8
(4,409 Views)
