context help
saverio.mercurio wrote:
> BINGO!
> Well, sort of...
> It's actually two things. I had MusicMatch running, but not playing.
> (Processor time was not at 100% for those of you thinking that. It was
> barely hitting 10% while I was working.) If you quit out of it the
> context help eventually wakes up. However, I discovered that it's also
> tied to whether or not the objects you're hovering over are enclosed
> in some sort of structure, like a case structure, sequence structure,
> loop, etc. If they are the context help window gets "stuck" and only
> works correctly if you quit out of MusicMatch. If the objects are just
> "loose" on the diagram the context help works correctly regardless of
> whether or not MusicMatch is running. Who'd've thunk?
> Definitely something I will forward to NI. Whether or not it's a
> problem with LabVIEW is a different question.
> Much appreciate the suggestion!
Saverio,
I'm glad someone pinned this down. I have noticed the same problem,
but hadn't bothered to work through it all the way. I do have
MusicMatch running most of the time, but I had never thought that that
would explain it! Very strange interaction. Anyway, just wanted to let
you (and NI) know that you weren't the only one to see it.
Dave
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Developer
Certified Instrument Driver Developer
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
There are 10 kinds of people: those who understand binary,
and those who don't.
Message 11 of 11
(486 Views)
