constructor node release
I use constructor node to create an instance of a .NET object,in my VI case, I noticed from windows task manager ,the memory of labview increase 5 MB after every runs,I would like to know how to release the memory after VI finished, it doesn't work if use "Close Reference" function.
Thanks.
(2,593 Views)
Hi
You should always use Close Reference regardless of any other issues.
Can you post an example of the code (in Labview 2012 or earlier).
(2,570 Views)
