constrained nonlinear optimization
Dear,
Using the "Constrained nonlinear optimization" vi (click) I sometimes get the error -20071 "The input matrix is not positive definite".
What can I do about it?
Thanks for any advice!
(3,361 Views)
there is already a bug reported for this issue if all coordinate at the start terminal are zero. A workaround is by wiring non-zero coordinates to the start terminal. A permanent solution is predicted for LV 2014.
Michael
(3,350 Views)
Please find attached a sample vi (LV 8.6) containing 2 data sets.
One of them with error, the other not.
(3,349 Views)
Hi Michael,
Thanks for the reply but I never use zero as start coordinates.
So if there is a bug there I never wake it up Smiley Happy
As you will see in the example vi I posted I try to calculate the minimum zone circle of the given data set.
As start I uses:
X and Y result of the "Fitting on a sphere" vi
minimum radius is half the smallest radius in the data set
maximum radius is 1.5 times the largest radius in the data set
(Please note that I excluded those calculation sfrom the test vi!)
So I'm pretty sure I never have all start data set to 0.
Best regards
(3,333 Views)
