constellation with raised cosine filter
I want to understand, why we're using the filter: root raise cosine than we've got to the symbol map constellation TX: 0.4 + 0.4i, and in this case, the symbol represents several points, that's true it should be TX: 0.7 + 0.7i, like filter: non, thanks.
(2,436 Views)
Hi fipelec,
I think that if you want to get any useful help with this, you're going to need to provide some more information. At the moment, two front panel screenshots doesn't really tell me (and presumably, anyone else) much about your code.
Can you perhaps attach a VI or at least show the block diagram that's causing you problems, and try and describe in a little more detail the output you'd like compared with what you have?
GCentral
(2,423 Views)
