connection problem using TCP and Shared variables
Hi
I have an project(host and a real time device) using shared variables as well as TCP to send images across the network. I am familiar with using TCP in labview but never used TCP and shared variables in the same project before.
I keep receiving error 63 out of the TCP open connection. This only happens if an executable is formed and deployed on the real time device.
Is there something to watch out for if using shared variables and TCP?
JChec
(3,204 Views)
Dear JChec,
Here are a couple of troubleshooting Knowledgebases for your reference. These contain a discussion of most of the pitfalls to avoid, and hopefully they'll be able to get you up and running again.
Why Do Two LabVIEW VIs Using VI Server Stop Communicate After I Build Them Into Executables?
http://digital.ni.com/public.nsf/allkb/92AA97AEB10BD479862567C90071B54D?OpenDocument
Error 63 With the Host VI Generated by the Communication Wizard
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MQ3SAM&l=en-US
 Why Do I Get Error 63 When Running an Executable?
http://digital.ni.com/public.nsf/allkb/98F70807876580D286256F4A0071827A?OpenDocument
Best Regards,
~Nate
(3,171 Views)
Accepted by topic author JChec
Thanks Nate
Fiddled quite a bit and found that the TCP worked great if I deployed from another computer. Thanks for links, they were good reads
JChec
(3,160 Views)
