connect.vi
HI,
I am a new user in LabVIEW, and above all, a new user in SQL and Connectivity Toolset. I have an old program where the connection to the database is done by the SQL connect.vi, but in the examples I have found do they always use DB Tools Open Connectio.vi. What is the difference between these two? Does it matter which one I use? Or is it just a matter that the old program uses SQL Toolset and the examples I have found are reffering to The Connectivity Toolset?
Thank you!
(2,662 Views)
The new one is based on something called ADO which is a database connection API from Microsoft. The Database Connectivity Toolkit replaced the SQL Toolkit several years ago. The SQL Toolkit used a completely different type of connection and you cannot mix the two. If you are doing new development, the DCT is the way to go.
(2,656 Views)
